Hi-Lo Inputs Upgrading On A Budget
So here is the dealio, I am installing a PBR300 and Infinity Kappa 62.11 on my 03 Glide. I need to keep the stock HU for now and mostly I listen to my I-Pod while riding. Front fairing only. I need to use the high level inputs for now so any advice on this? I plan to cut the harness as advised in the instructions for the amp inputs and hook up that way for now. I know the low level is the best but ain't going that way for right now. I am going to run 10 gauge pos/neg from the battery fused of course. I plan on mounting the amp on top of the HU maybe with a plastic or aluminum plate to use as a buffer between the amp and HU. What I am asking for is any suggestions on doing this. Thanks in advance!
I was referring to the harness that comes with the amp. I agree with you that cutting into the bikes wiring harness is less than desirable.
Damn! I had it all set up to go with a Kicker high/low converter but I really do trust you guys as I have no experience with this stuff. I always thought low inputs would be better but I will go with whatever you guys say, just need some reassurance on doing it with the high level inputs. I have been waiting on some new speaker grilles as I had that J&M crap speakers in there from years ago and had to order new stock grilles which will be here today and I was going to wrap up the install. Cutting those wires and going high level is no problem just need to hear that is the way to go! Thanks!
Yes 100% the way to go.
You normally get better sound quality with low level inputs, but that amp sounds much better with a higher input voltage that you get from high level inputs. So whatever minimal soundquality you lose with this specific amp you gain in volume and dynamic sound. I wouldn't think twice about it with that specific amp.
