Amp and speakers for my 2010 road glide???
I was going to buy a $300 Rockford amp and speaker kit off eBay but everyone said I had to come here first.
2010 Road glide, stock head unit, one blown speaker, I have $300-$350 to spend.
What's the best bang for my $$$, amp and speakers that I can install?
Thanks
Thanks
http://www.onlinecarstereo.com/CarAu...ity_6211i.aspx
http://www.ebay.com/itm/Cerwin-Vega-...0AAOSwu4BVvVJK
Not "plug and play" but easy enough to install
Gannicus (03-19-2016)
Need the Cerwin Vega B54 to incorporate the rear speakers. The Infinity Kappa's are two ohm speakers and can't be ran in parallel with the B2. If your bike is 2014 or newer you will also need the biketronics line levelers to run with the stock HU. 2013 and below requires you to run high level inputs to the amp off the stock HU.
