2016 street glide speaker and amp upgrade
Hey everyone, I've been looking into upgrading my new 2016 sg specials audio system. Just the fairing speakers and adding an amp. What's going to be the best bang for the buck on these new bikes? I had biketrinics 7.1 speakers and a j&m 250watt amp on my 13 street glide which was a killer combo. Should I just go with a good set of speakers and a Rockford fosgate 300 amp
Or go HD boom stage 2 with amp
J&m rokkers with 330 amp
Or the biketrinics set up?
Well, since you've already experienced the BT 7.1s...............
The BT is by far the best of the setups you mentioned. If you still have the 7.1 just get the BT brackets to ditch the pods, line leveler, and 2180 amp and you're golden (or 4180 amp in case you want to expand later).
I've owned BT and JM so I can tell you it's ok to throw up in your mouth a little bit any time someone mentions JM. Same goes for boom II, not even in the same class as BT.
The BT amps have no adjustments on them. The amp controls the gains automatically. The BT355 Line Levelers do have Gain and HPF setting on them if needed. If you purchase the 2014+ kit it come with the Amp, speakers, speaker brackets, line levelers and wiring to make it a plug & play setup.
I chose the BT kit with 7.1 pro's and upgraded to the 4180 amp for an extra $100, being I plan to add speaker lids in the future. I'm just about done the install. Just need to add backer rod and polyfill, then button up the fairing. I can say this though...without the shell back on, and with nothing to seal gaps, this sucker is LOUD and quite clear! I mean like make you're ears hurt loud.....but I likey! Lol
