what speakers to use
What 400 watt amp? If you are blowing speakers it's in the set up. Kappa's take a lot of juice 5.25 and 6.5. Tough to blow those speakers unless the gains are maxed out and your volume is turned all the way up.
I had the same problem with the Kappas but I only lost the tweeters. They like the power but not for long. The tweeters must be the weak link with my set up with the Soundstream PN4 1000D pushing them
