15 FLTRXS on a severe budget
The B2 never effected my FM on my 2015 FLHXS
The B2 is rated at 250Wx2 at 2 ohms, so you should have plenty of power for the Kappas, I just don't have any experience with the Kappas. I had the B2 hooked up to Moto 602's at 150Wx2 and it was definitely way better than stock. Only changing the amp because the 602's like more power, as much as twice the power.
The 602's are mounted on the outside of the pods and using stock grills. So far no problems, but I haven't took the pods out to check yet.
I have the Road Glide do I still need to mount the Kappas inside the pod? If so is there a video specific to the RG?
If not I may have to at least take a bunch of pics when I do mine so as to help the next shark owner.
Also, is there a place for the port that is better than another is closer to the speaker, closer to the front of the faring, sideof pod(pointing toward the middle of the faring) and is 2" or 3" better or should I split the difference and make it a 2.5"?
Crap 1 more question, with the B2 should I run 10 gauge or 8 gauge power wire to the amp?
Sorry for all the questions but I really want to do this right the first time and not have to tear half the bike apart twice.
Thanks again,
Mike
Thanks again,
Mike
Last edited by beatlesfab4fan; 03-06-2016 at 03:45 PM. Reason: added a few more questions.
On RG they drop right in from the front/grill side. Much easier install. Also recommended is that you seal your pods with some silicone.
