Speaker position
02-29-2016, 08:11 PM
Speaker position
Hey guys,
2 part ? For today...
Got a set of biketonics bt477 (4ohm 6.5), a set of infinity 62.11i, and a soumdstream pn4.1000d amp..
Which set should I put in batwing/ which set for lower fairings?
Leave the biketronics at 4ohm or cut them to 2?
02-29-2016, 08:24 PM
I'd put the Kappas in the fairing, they will play louder, and provide better low end in the fairing.......
.....but how are you going to put the BT's at 2ohm?
02-29-2016, 08:37 PM
Wasn't sure if you could run the bts in parallel or not?
Dumb question I guess.
If there ok to run at 4 ohms I will. I'm not a sound system guy by any means. Just asking the best set up for the stuff I got.
02-29-2016, 08:44 PM
You're good with you got man! There's plenty of juice behind that amp to get PLENTY of volume.
03-01-2016, 05:46 AM
In my experience with both sets of those speakers, whichever you put in the fairing will be the ones you hear better. I preferred the 62.11's in the upper, with the BT's in the lowers. It won't matter to the amp that one set is 4 ohm and the other set is 2, providing you don't put a BT and 62.11 on the same channel.
Rckoutwurcokout
Audio Systems
19
04-03-2019 11:09 PM
billablehours
Audio Systems
01-31-2017 10:29 AM
pdevore
Audio Systems
19
07-16-2016 04:09 PM
NorthEnd
Audio Systems
03-22-2016 04:30 PM
PTAG
Audio Systems
13
07-23-2013 11:02 PM
