Just ordered SS pn2.350 what else will I need
Amps on the way as well as infin. Kappa 62.11 and adapters
Going in a 10 ultra with stock h/u
What else am I gonna need ...what wiring kit and guage? Line out converter?
Anything else?
New to this but want to do it my self.
Thanks for the help
Anything else?
Thanks for the help
Amp wiring you can use 6 feet of 10gauge wire red and black ,fuse holder and fuse
Or get an 8 gauge amp wiring kit from Wal-Mart for around $20
Some wire ties to clean up the wiring
I had to lengthen the speaker level harness a bit but other than that it was a easy set up. I also used a 8 gauge wiring kit.
Remember you do not need a turn on wire when using speaker level input. Also the speaker level harness has 5 wires. Pos and neg for each speaker and a ground wire. I didn't use the ground .
