Audio quality bike started vs not started?
Old 02-14-2016, 10:52 AM
rhallman's Avatar
rhallman
rhallman is offline
Default Audio quality bike started vs not started?
Has anyone actually figured out how to fix the issue where the sound audio is the same with the bike started and not started? Its frustrating to hear how well the stereo sound is when the bike is not running vs running. Is this a flash fix?
Thanks...
Rich
Old 02-14-2016, 06:20 PM
roussfam's Avatar
roussfam
roussfam is offline
Received 7,220 Likes on 3,753 Posts
I guess I'm not understanding the problem... you're saying your system sounds better when the bike is not running??? Just a heads up. You might get some interesting responses.
Old 02-14-2016, 06:41 PM
Bertk's Avatar
Bertk
Bertk is offline
Need more info.
What bike are you talking about?
Is there an amp installed?
Has the HU ever been flashed by the dealer?
Old 02-14-2016, 06:49 PM
rhallman's Avatar
rhallman
rhallman is offline
Bike is a 2016 SGS. No flash and has the stock bin file. 01_off.bin I have the Micro4 v2 amp with the Biketronics line leveler installed and Hertz 6.5 coax speakers mounted on the biketronics speaker brackets that replace the pods. Thanks...
Old 02-14-2016, 06:52 PM
captbc's Avatar
captbc
captbc is offline
Stage I
Yea same here 2016 flhtk bike is running music playing, hit the kill switch sounds way better no idea why ?
Old 02-14-2016, 06:58 PM
haze324's Avatar
haze324
haze324 is offline
how are you setting your gains? With your bike off the amp sees just above 12 volts with the bike running 14+ volts, which is likely causing distortion at the same volume on your bikes. Also, you're not getting the most out of those Hertz coax's with the Diamond amp unless you have that sucker bridged....so it's likely you are cranking it too much with the bike running in addition to the 14v's.
Old 02-14-2016, 07:04 PM
Babyboy's Avatar
Babyboy
Babyboy is offline
I have noticed the same with my 14 limited.
Sound quality is different. What I am guessing is the bin file off and on have different eq curves.
I have better bass with the bike off than running.
Old 02-14-2016, 07:24 PM
TomboAT65's Avatar
TomboAT65
TomboAT65 is offline
It's the same even on a completely stock system. The EQ files for off vs on are different. Not idea why they did it that way.
Old 02-14-2016, 08:11 PM
Bertk's Avatar
Bertk
Bertk is offline
And if your using the AVC that will increase the voltage even more.
Old 02-14-2016, 08:21 PM
haze324's Avatar
haze324
haze324 is offline
There's a post somewhere by Bill where he discusses the difference in curves when on an off designed so speakers won't blow at volume/speeds when running.
Quick Reply: Audio quality bike started vs not started?
