NVX MVPA4 & ARC Moto 692
Actually looking for specific amp settings too, but u bring up a great point.
My plan is to use the rear channel LL thus when I Y off the LL I will essentially now have 4 RCAs that need to be plugged into two amps. I get that two of them (red and white) will go back into the rear channel on the BT4180 but I have 4 RCA input holes in the new amp. How the hell do I make that work with only 2 RCAs?
T
T
Y-splitter RCA's brother.
http://www.sonicelectronix.com/item_...er-SI62YM.html
You'll need this with any 4-channel you get. Wait, did you already get this one? I thought you were gonna give me the dimensions first trigger puller! If you did, gimme a shout when you go install it. Setting gains is easy-peezy bro.
Now i just have 3 sets of rca's. One off the front BT355 and 2 to the back Y'ed off the back BT355.
Originally Posted by matt76cmich
Yup. My original plan i was gonna have two 4ch amps with 2 sets of rca's coming off of both the front and back channel of the bike and bridge both of them to 4 speakers.
T.
Thanks again for your help with the wiring logistics!!!
T
Are you using all 4 channels of the 4180? If so, you would need 2 sets going to it. If you are using two channels from from the 4180 you might get by like that. I don't have any experience with that amp.
And how many amps are you running? And what speakers are going to what amps? Might help.
And no idea if they make a single male to three female rca adapter. That sounds like what you would need. I'm sure the more experienced guys will chime in on this.
It would be damn nice if I could find a 1 to 3 RCA then I'm done in one pass.
T.
