arc 125.4 vs BT 4180 or BT 2180c ?
Old 02-13-2016, 12:21 PM
Babyboy's Avatar
Babyboy
Babyboy is offline
Default arc 125.4 vs BT 4180 or BT 2180c ?
Originally Posted by bobbyjoes
That's worth it to get rid of pods,d
If $$$ is tight you can so something like this
Old 02-13-2016, 12:26 PM
Bertk's Avatar
Bertk
Bertk is offline
I didn't realize it until now but you have the bike in the kitchen!
Old 02-13-2016, 12:58 PM
bobbyjoes's Avatar
bobbyjoes
bobbyjoes is offline
Ya in dinning room,,got devorced 11 years ago and so this is my baby,been doing with different bikes since 2008,gives me something to do in long winter days in. Iowa,ha
Old 02-13-2016, 01:14 PM
matt76cmich's Avatar
matt76cmich
matt76cmich is offline
Attachment 459709
Did you have to make the metal peice to the left of the speaker? The bigger one by the radio. I can't remember what it looks like with the pod out.
Nice job by the way.
Old 02-13-2016, 01:21 PM
Babyboy's Avatar
Babyboy
Babyboy is offline
Originally Posted by matt76cmich
Food you have to make the metal peice to the left of the speaker? The bigger one by the radio. I can't remember what it looks like with the pod out.
The vertical bracket is for the cb module mount
Old 02-13-2016, 02:03 PM
matt76cmich
Nice. I might have to try this while i have everything tore apart.
Old 02-13-2016, 02:25 PM
LL247's Avatar
LL247
LL247 is offline
Former Sponsor
That's awesome!!! hahahaha
I did that before, had a townhouse with no garage. Pulled my Road King in the front door, parked in the dining room. I say this, your bike is family...it's allowed to be inside!
I was going to chime in on the audio question, but everyone has given good advice that I agree with. The Arc is a good amp, the 4180 is an awesome amp if you can pony up for it (the current sale is a damn good one too). Ditch the pods!
Old 02-13-2016, 03:38 PM
bobbyjoes's Avatar
bobbyjoes
well got the pods out ,it wasn`t that bad,so a dumb question,so i dont need a adapter bot the grills have to be replaced ,the balck mesh and bracket?
Old 02-13-2016, 04:44 PM
Tailwind's Avatar
Tailwind
Tailwind is offline
If you keep the pods, just screw the Focals to the outside of the pods and put the crossovers in the pods. No spacer. If you keep the pods, you might drill about a half a dozen random holes in the plastic to let the speaker breathe a little bit.
If you get the brackets, the speaks just screw to the predrilled holes. Get some 1/2 or 3/4 inch backer rod from Home Depot for a couple of bucks and put this in the gap between the mount / speaker and the inner fairing.
Either way you will need new speaker grills. The HD ones are nice but pricey. I might have an extra set in the garage. Also some of your audio brothers can probably steer you to the best value for grills.
T.
Old 02-13-2016, 07:15 PM
Bertk's Avatar
Bertk
Bertk is offline
If you use the BT speaker brackets, the stock grills will work.
Quick Reply: arc 125.4 vs BT 4180 or BT 2180c ?
