Help with HU/speakers/amp for 06 FLSTC!
Rose you're asking all the right questions and considering some very high-end stuff!! Good, that means you are doing it right and can not compare this upgrade to the Unique Cycle stuff.
That Amp and Speaker combo will sound fantastic at 80mph. Only thing is to find out if it fits in the fairing. Find out from Reckless how much room they have for a radio in there. I have that amp at home and take some measurements with the amp and radio inside a fairing to see if it fits.
Thanks for your input! Hopefully you guys know what you're talking about cause That's what I'm basing my buying decision off of. Haha I'm sure you do. I'm glad I found this forumn. I'll double check dimensions from Reckless, but sounds like Gannicus says I'm a-ok to proceed. Then, last thing will be to choose a HU.
What do I need to know besides other components I'm using when choosing a HU? I'm really not sure how I will run my music yet or what is the best option. iTunes, usb, radio... Combo of them all I'm sure. I'm so technologically challenged when it comes to all that stuff. Any input or ideas there??
I like the Kenwood because you can reverse the color display on the screen and it lets you see it a little better in the sunlight. The Sony is Marine rated for whatever that worth in protection. I would stick to one of those as they are proven units.
Music sources. There's a good chance that any amp you choose is going to kill or interefere with some FM reception. I normally play everything off of USB and for longer trips I can Bluetooth or plug in my cell phone and stream Pandora, Spotify, Radio Apps. Never FM. Best sounding source will come from a "flat file" on a USB or CD.
SBates08, Haze324, Gannicus
