Battery posts are getting crowded
In addition to the factory power and ground cable on my battery, I have hooked up air compressor wires, electric center stand wires, heated gear wires, and 1 amplifier (B52). I am about to install a second amp (another B52) and the battery posts are getting a bit crowded. Just curious what yall are using (if anything) in the form of power and ground distribution to clean up the terminals a bit? Or is it fine with all of the wires connected to the battery and not need to be concerned?
I went 8 all the way around. Neither amp is going to draw what the main line is putting out. Hell, the whole bike is run in under the 8 that is powering my amps. Lol
I bought the stinger block that you suggested. Did you fuse the main cable going into the block or fuse each cable going to the amps separately?
I fused the main cable. I had actually bought the boss wiring kit but used only the fuse holder and fuse from it because I had extra wire from a previous install. But there are inline fuses available on eBay too.
