xm install
Received 49,832 Likes
Make sure your have the connections in the correct locations. (Take it from someone with first hand knowledge. The connector will fit into more then one connection point!)
Also, as Uncle Larry said and I assume you have one - a subscription (although you should still get their info channel for output)
