Audio install on 2010 street glide help
So I researched several posts on audio and decided on infinity kappas 62.11 and a RF Pbr 300x2 amp. Only problem is I can't find the specific install info from Ultranutz. I see the sticky on audio forum page but can't find info on my bike and setup. It sounds from other members that is an easy install. Any help appreciated. Thank you.
I'm sure the gurus will chime in, but here's the basics:
- run power and ground for the amp (ground at the battery)
- use high level input for the amp (this will take a little splicing - run wires currently going from the stock head unit to the speakers to the input side of the amp)
- run new speaker wire from the output of the amp to the speakers, 16 ga is fine
- will need adapter rings for the kappas
- follow the sticky to set your amp gains by ear. Most guys will go with amp in HP somewhere around 90 hz to start.
That should get you started, are you looking for anything specific?
aftermarket /make and model#
You don't have Low level connections on the stock HU. Low level inputs are generally associated with aftermarket HU's. Hence you will have to run High Level inputs to your amp.
