Biketronics fairing speaker brackets
I think it depends on the speaker that you are using, some speakers need to breath sort a say may also prevent them from running hot, others sound better in a inclosure.
After all the trouble I went to removing the pods, I'll be darned if I'm going to put them back on. I spent more time than I wish to admit too, trying to put together the right combination of tools, etc. getting to those two pesky bolts that are down under the radio mounting frame. Once I figured things out, the second pod only took 15 - 20 minutes to remove. For those who are about to attempt removing the pods I will sell you the tool combination that will work.....for say.....$10.00. LOL!!!
After all the trouble I went to removing the pods, I'll be darned if I'm going to put them back on. I spent more time than I wish to admit too, trying to put together the right combination of tools, etc. to bet to those two pesky bolts that are down under the radio mounting frame. Once I figured things out, the second pod only took 15 - 20 minutes to remove. For those who are about to attempt removing the pods I will sell you the tool combination that will work.....for say.....$10.00. LOL!!!
Pussies.
Pod Knuckle is like a badge of honor, showing you've been there, in the trenches, and beat it.
__________________
NO, they DON'T all do that!
Also on amazon.com...
