I have mine on the BT tray, and it works fine for me. However, I am always open to new ideas. In addition, the XM signal is much better now; in fact it is much better than when it was mounted above the HU.
That's good to know Paul.
What do you think of the XM sound quality compared to USB stick?
I am getting an occasional weird sound from the right rear speaker. It sounds distorted at times when the bike is running. I cannot duplicate it with the bike shut off, and it is not a consistent weird sound when it is running any ideas?
Than in advance,
Paul
Anything plugged into the power port in the tour pack on that side?
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
Than in advance,
Paul
Ya, that may be the issue. The HD speaker connectors were bigger then the tabs on my rear speakers so I kinda just crushed them on with a pair of pliers. Hey it was late and I was in a hurry to hear the sounds.
Thanx,
Paul
Than in advance,
Paul
Originally Posted by Bertk
Start simple and check for any loose wires.
Thanx,
Paul
Changed the connectors to the right size for the Alpine SPR60's rear speakers still have distortion issue. However, I did switch the speakers left to right and the distortion followed the speaker. Thought it had to be a speaker issue, but I installed a brand new one and still have the problem. I am waiting on a call from Bill at BT. the distortion sound is hard to reproduce so it may have been effecting both speakers from the get go.
Paul
Paul
Bummer. Did you check the RCA's and wiring under the fairing?
If you unplug the molex connectors look in side each of them and make sure all the pins line up and none are pushed back. You could do the same with the breakout harness.
