Odd radio issue
Old 12-11-2015, 12:34 PM
tuleyne's Avatar
tuleyne
tuleyne is offline
Originally Posted by Diverrick
OK thanks for the leads. How do I check the coax? it is all sealed up with coating from one end to the other? Put a small hole in the sheath?
Also, meter the connectors at the cig lighter when the bike is on run. You may also want to sandpaper the spade connectors in case there's some oxidation built up on them.
Old 12-12-2015, 09:51 AM
im's Avatar
im
im is offline
Does cig lighter have power in run position?
Buelligan666's Avatar
Buelligan666
Buelligan666 is offline
What headlights are you using? I know some LEDs have been causing interference for guys. Is there any other electronic devices that turn on with the ignition, but don't when you switch to aux? Just spit balling here.
Old 12-12-2015, 04:54 PM
Diverrick's Avatar
Diverrick
Diverrick is offline
Good question, I'll take a look as soon as I can.
Old 12-14-2015, 06:15 PM
Reefdiver72's Avatar
Reefdiver72
Reefdiver72 is offline
Stage III
Default Try hooking to spare power on headlight
Cigarette lighters pull a draw if they have been wet or shorted before and wires arent very heavy try the headlight acc. Plug.
fxrtharley
07-14-2018 08:30 AM
FHubbard4
Audio Systems
05-13-2015 08:38 AM
Ghosttrain1
10-09-2013 02:06 PM
WannaBuy
03-16-2009 09:04 AM
SULLY 58
12-20-2005 10:24 PM
Quick Reply: Odd radio issue
