Dealer flash to add power amp
2010 Limited with some stuff
surfnorthwest,
I think the Harley radio flash that works the best with the BikeTronics line levelers or J&M Green band RCA input adapters is here http://www.jmcorp.com/pdf/HarleyRadi...09-10-2015.pdf
This Harley radio flash will activate the rear channel outputs, turn on the front/rear fader control, allow AVC operation and full bass/treble control.
Hope this helps you.
__________________
JM-ANDY
J&M Corporation
1415 S. Cherry Ave.
Tucson, AZ 85713
Andy@Jmcorp.com
1-800-358-0881
For HD-Forums VIP Promo $$ discount code send email direct to Andy@Jmcorp.com
JM-ANDY
J&M Corporation
1415 S. Cherry Ave.
Tucson, AZ 85713
Andy@Jmcorp.com
1-800-358-0881
Replace the magic box with the BT Line Leveler and secure it. Using the LL there is no need for a flash that may work or most likely won't work. It is recommended that the bike have a stock flash when using the LL.
The op has a flhtk so he has the fader already and I just did my flhtk with just Line levelers and you DO NOT want the AVC controls on or activated
So can you explain this little issue I had the other day with my 14 limited.I had my AVC on third bar wear I always ran it with stock system and volume set to about 10 bars. Everything was all great in town below 40mph and got on the express way ran up to about 70 mph and within 2 min. At that speed all 4 of my tweeters quit working.I did not change any settings while moving.I ran my system for 2 hrs at mid volume and it didn't miss a lick and sounded great. To me the only thing that changed in the equation was the AVC was more active at the higher speed.
