Those speakers look awesome...but are out of my price range. Did I mention budget?? Lol. Really trying to stay under $200 for the rear speakers? Any suggestions on an amp? Thanks guys
Gannicus, those Kappas look like the ticket. I don't listen to FM...normally stream audio (Pandora/ITunes library) from My iPhone which will be plugged into the rear USB. Thanks again for the help.
Soundstream PN4.1000D all the way with the Kappa's! That system rocks big time!
Do you guys know if the Kappas fit in the factory 5x7 saddlebag lids? I was going to order the from Sonic as Bertk ^^ suggested but the 6x8 in the description gave me pause...???
Thanks again for the help. Planning on the Soundstream amp and the Kappas if they fit!
5x7 and 6x8 footprint is usually the same. The kappa's should fit no problem.
Gannicus....Thanks for the advise!! Bertk....Thanks for the info on the Kappa price!
Ordered both the Kappa's and the Soundstream from Sonic tonight!!! Biketronics in the front Kappa's in the back and the Soundstream pushing them should be great!?!
I'll second the amp
With a stock HU on a 14 limited and kappa 62.11i with some low $$line levelers my system ROCKS I can't wait till I get the BT levelers
