Amp Install questions... Help please.
My amp went out on my last road trip, so I figured it was time to upgrade. I went with a Soundstream PN4.1000D 1000W 4-Channel Picasso Nano Series Class D Amplifier. Pulled my fairing and pulled the old amp out. The new one has some different hook ups and I'm electronically challenged. Hoping somebody can help me.
First off is what I had:
This is the male plug that plugged into the amp:
But the amp has this female input:
Do I cut that end off and solder on this one?
And do I just match the wire colors or is the order from left to right?
Finally, last question: I have lower fairings installed with HD boom speakers in them. They are powered by the radio only and were not connected to the mini-amp I had in there. I'd like to wire them to the amp since I have a four channel amp now, but I cannot figure out how to identify the speaker wires from this madness coming out of the factory radio.
Can anyone help me figure out how to do this? I'm electronically challenged, but I can strip wire and solder, just needing some guidance.
Thanks.
Thanks.
Yeah I took a look at the thread. A couple things. Use the RCA's for inputs rather than the High level speaker inputs. You will have to purchase two SNI-35 line levelers and two male RCA's to accomplish this. secondly the SS PN4.1000D is a very powerful amp @ 250 watts @ 2 ohms. Your boom speakers in the lowers will blow if the gains are set too high.
Will these work for the SNI-35 line levelers?
I'm completely lost as to the male RCA's to buy.
I may not be the smartest kid in the class, But here's what I would do. Clean that up and get one of these. It's what I used before upgrading my HU. It's a line output converter connect stock speaker wires to input and use RCA cables from output to amp in. This is just a 2 channel in pic but you can get a 4 channel. Then just run new wires from amp to speakers.
Edit: Oh I'm not sure if those speakers will work good with that amp, Might just blow em up. I'm sure one of the tech's around will add info soon.
And I'm gonna have to swap the speakers. Somebody already chimed in on that on another thread.
