Line Leveler issues, sigh, I know BT will come through.
Old 11-27-2015, 12:05 PM
JimTJr's Avatar
JimTJr
JimTJr is offline
Default Line Leveler issues, sigh, I know BT will come through.
Ok, went to dealer today, Sheltons, in Goldsboro, NC. He didn't charge me anything to re-flash to this setting from what it was. Kudos to him for trying to help me, I don't want to keep bothering him until I know WHAT I need from them? Bill told me to have them just enable Fairing and rear Speaker pods, no amplifier module. I have a call into BT, however they may be off today, long weekend, good for them if that's the case!
I hate talking into a answering machine, or video, LOL. My "Words" are a little scrambled. Either way, I have bass / treble & fader, but sound quality from rear is not great, with some popping from one, and low output from the other.
Here is a video of my "Flash" along with a "Speaker test" from the diagnostic on radio. I don't understand, I now seem to have the "Flash" everyone else says they had before (02_OFF.bin) that was so good, where I had the weird one in sig, that no one understood why? (But it sounded good to me with the SNI 35s in before the Line Levelers)
Old 11-27-2015, 04:50 PM
JimTJr's Avatar
JimTJr
JimTJr is offline
Thoughts? Really hoping I didn't have to wait til Monday to hear from BT. And this dealer is closed Mondays...
Old 11-27-2015, 05:52 PM
timbo141's Avatar
timbo141
timbo141 is offline
Jim, your video is set to private.
So you swapped out two SNI35 with two BT335
Had your radio flashed from 210_OFF.bin to 02_OFF.bin (Which is the bin file I have and sounds great)
Rear speakers sound weak...
Maybe you need to reinstall the 1.19.1.1 update and see if that fixes things.
Old 11-27-2015, 06:47 PM
JimTJr's Avatar
JimTJr
JimTJr is offline
Changed settings to public now, I would have hoped he'd load the newest software,, I'll download it and install tonight.
Old 11-27-2015, 07:02 PM
timbo141's Avatar
timbo141
timbo141 is offline
Jim have you tried swapping the two line levelers to see if the problem stays with the rear or if it moves to the front?
Just a way to see if the one hooked to the rears is bad.
Old 11-27-2015, 07:59 PM
JimTJr's Avatar
JimTJr
JimTJr is offline
different ones, rear has a plug for rear speakers, front is just spade connectors,, I had clear sound front and rear with the other flash,, just not as much volume as with the SNI35s... and now with this flash, still not great volume,,, and rears are messed up...
Old 11-27-2015, 08:53 PM
timbo141's Avatar
timbo141
timbo141 is offline
Couldn't you just switch the RCA cables and try it that way?
I would also try the universal one on the rears too. You would need to use the OEM speaker connectors and plug the spade connectors in the other end of OEM cable. (The way you had the SNI35 hooked up)
This way you could start troubleshooting. Monday will feel like an eternity away...
Old 11-27-2015, 09:48 PM
Bertk's Avatar
Bertk
Bertk is offline
A couple of thoughts.
Remove the fuse to the Amp for a minute or so.
Reinstall fuse and check sound.
Update software to 1.19.1.1
If already updated, reset radio to factory default.
Export GPS maps if you want to save them.
Check sound.
Old 11-27-2015, 10:04 PM
Bertk's Avatar
Bertk
Bertk is offline
I have the 2015 FLHTK and here's what I have for EQ. This is stock and has never flashed.
Old 11-28-2015, 05:52 AM
timbo141's Avatar
timbo141
timbo141 is offline
00_on/off.bin is the stock flash for two speaker no amp
02_on/off.bin is the stock flash for four speaker no amp . Basically same EQ settings as 00 with rear speaker terminals and fader enabled
Quick Reply: Line Leveler issues, sigh, I know BT will come through.
