2014 Limited rear speaker upgrade
Old 11-23-2015, 06:34 PM
Babyboy's Avatar
Babyboy
Babyboy is offline
Default 2014 Limited rear speaker upgrade
Has anyone installed Infiniti Kappa 62.11 in the rear speaker pods or know if they will fit.
If they don't fit I am looking for recommendations for the rear speakers.
I'm ready to pull the pin on my winter upgrades
Old 11-23-2015, 09:05 PM
Babyboy's Avatar
Babyboy
Babyboy is offline
Forgot to mention going to be using SS PN4.1000D amp and kappa in front
Old 11-24-2015, 05:48 AM
NHBAGGER's Avatar
NHBAGGER
NHBAGGER is offline
Been asking the same question and the consensus seems to be sometimes they fit and other times you need to add a spacer of about 1/2". Some like the Polk MM651 back there although in the past there was a quality issue.
Old 11-24-2015, 07:01 AM
Gannicus's Avatar
Gannicus
Gannicus is offline
Correct. Otherwise your options are the Alpine SPR 60, the Kicker KSC674's, the pioneer TS-A1686R, the Polk MM651's, the DD CSX 6.5's or the Hertz DSX 170.3 6.5's. All these speakers will drop right in your rear pods with 4 screws. My favorite in that location are the Polks. But they all sound very good in that location.
Old 11-24-2015, 07:20 AM
NHBAGGER's Avatar
NHBAGGER
NHBAGGER is offline
Any of these 2 ohm other than the Polks?
Old 11-24-2015, 07:25 AM
Gannicus's Avatar
Gannicus
Gannicus is offline
No Sir. The Polks and the Infinity's are the only 2 ohm in the bunch. Won't matter with the 1000D.
Old 11-24-2015, 07:53 AM
Babyboy's Avatar
Babyboy
Babyboy is offline
Has anyone used Infinity Reference 6032cf in the rear pods?
Old 11-24-2015, 08:13 AM
haze324's Avatar
haze324
haze324 is offline
Here's a good post by Seesaw
Originally Posted by Ride my Seesaw
You guys are all being led around by your noses by the stereo marketing people with regards to impedance. Your speakers aren't really 2 ohms, 4 ohms, or 8 ohms at all. They might qualify to be called 2 ohms because at some NARROW point within the whole audio bandwidth of the speaker they might represent a 2 ohm load. Same goes for other impedances. For example, I have Hertz HCX-165 coaxial speakers, they are considered a higher end speaker and rated at 4 ohms. But are they really? Well luckily Hertz publishes the impedance curves for their products. http://www.hertzaudiovideo.com/car-a...energy-hcx165/ Just click on the 'frequency response' tab when you open the link.
We can see from the lower black curve that the speaker only reflects an impedance of 4 ohms between 150 to 500 Hz, and again between 12 to 16 kHz. Every other audio frequency is not being fed into a 4 ohm load, and is actually quite to the contrary. The speaker's impedance is roughly 9 ohms at 3.5 kHz and well over 28 ohms a little above 50 Hz. Most of the useable music audio is going to be between 700Hz to 10kHz, this is where the impedance rises and falls to anything but 4 ohms, as shown in the graph. Lots of Bass between 150 - 500Hz but not much music or vocal content there. Same with 12-16kHz, lots of very high trebles but not much music content.
Think of speaker load like tires against the road surface. The smaller or larger the diameter of a tire being driven against the road will reflect the maximum power it can transfer into that load. A smaller tire will spin faster but will run out of efficiency at higher road speeds and unduly load your engine. The larger tire will unduly load your engine as it try's to turn it from a standstill or a very low speed. You simply want the correct ratio tire for your overall engines health. Not to big and not to small. Same goes for matching speakers. It's not quite the perfect analogy but enough to give you the picture.
Old 11-24-2015, 11:30 AM
Gannicus's Avatar
Gannicus
Gannicus is offline
Last guy I knew had those. Blew them up! I don't think they are very good quality.
Old 11-25-2015, 03:51 PM
Jeff Davis's Avatar
Jeff Davis
Jeff Davis is offline
Is there any way to get the moto 602s in the rear speaker pods?
Quick Reply: 2014 Limited rear speaker upgrade
