15' street glide. 2- pbr 300x2 or 1-rz43000d
Old 11-05-2015, 03:49 PM
sponger's Avatar
sponger
sponger is offline
Default 15' street glide. 2- pbr 300x2 or 1-rz43000d
So guys, i have the 62.11 kappas in fairing, and i went with v-twin audio diy saddlebag 6x9s. The 6x9's are the ones they sell. Kicker css694. I already have 1 pbr 300x2 and it works great. I had bought the cv b52 to use for the rears but the 1st one was no good. Only 1 channel worked. I sent it back and got another. It was ok, but when i turned up the stock radio, the speakers would shut down. Long story.
So i returned it as it was the cerwin vega b52, that was messing up. So now i want to know, should i do another pbr 300x2 to go with the other one, or go with a good 4 channel? Like a rz4-3000
Old 11-05-2015, 04:04 PM
SBates08's Avatar
SBates08
SBates08 is offline
Received 1,239 Likes on 1,002 Posts
If you don't mind the possibility of losing FM I'd go with the RZ4 any day of the week over the PBR.
2010 Limited with some stuff
Old 11-05-2015, 04:13 PM
AAWAV's Avatar
AAWAV
AAWAV is offline
go with the SS (or PN equivalent). as SBates already mentioned, IF you do not care about potentially losing FM.
IMO the SS / PN got more "*****" and you could sell the PBR to offset the money spend (actually it would be cheaper to by the SS / PN than another PBR).
Old 11-05-2015, 04:28 PM
sponger's Avatar
sponger
sponger is offline
I couldnt give 2 ***** about fm radio. So now, do i go with the rz or the ss/pn? Pros/cons
Old 11-05-2015, 04:30 PM
sponger's Avatar
sponger
sponger is offline
Oh and i figure with the 4 channel amp, id hookup the kappas like usual, and hookup the 4 ohm kickers in parallel?
Old 11-05-2015, 04:54 PM
just plain john's Avatar
just plain john
just plain john is offline
I think the RZ3000D is out of production, but the Soundstream 1000 is virtually identical
Old 11-05-2015, 05:04 PM
sponger's Avatar
sponger
sponger is offline
I see that sonic electronix still had them in stock. So knowing that, should i still do the soundstream instead?
Old 11-05-2015, 05:09 PM
SBates08's Avatar
SBates08
SBates08 is offline
If your just gonna run the 1 set of 6x9's on the rear channel it makes no sense to run them in parallel with that amp. You'll be cutting your power if you do so.
Old 11-05-2015, 05:15 PM
SBates08's Avatar
SBates08
SBates08 is offline
They're both the same amp. The RZ just happens to be cheaper.
Old 11-05-2015, 05:23 PM
nick4737's Avatar
nick4737
nick4737 is offline
If you go with either the ss or the rz amp you at going to have to buy the amp mounting bracket from Jm
Quick Reply: 15' street glide. 2- pbr 300x2 or 1-rz43000d
