What gauge speaker wires should be used when adding an amp?
Will the "stock" wiring on a 14 limited be capable of added power with an amp and aftermarket speakers or should new wire be ran from amp to speakers? If so what gauge
Thanks in advance trying to get everything together for the winter UPGRADE
We upgrading again Bayboy? LOL! You got it bad man! Use 16 gauge wire.
the thicker the better IN GENERAL...
will you hear the difference on the bike? NO.
one of the aspects is f.e. the length of the cable... the longer the "run" is the "more" you need a bit thicker wire.
of with anything you got laying around from 14-18 AWG
