AquaticAV AQ-MP-5UBT-H
Ok, does anyone know if this has an internal fuse? It stopped working the other day and after checking the existing fuses, grounds, and wiring I couldn't find the problem as to why it wouldnt power up. So I connected my old Biketronic Sony DSX-MS60 and it powered up just fine which leads me to the conclusion of a defective Aquatics unit... (unless it has an internal fuse?)
Joys, Lonestar Rally is coming up and am having stereo issues...
Update, removed all connections, pulled the unit out, and reconnected the 23 pin connector and it powered up now. Am at a loss, any ideas?
Ok, solved....
Seems that the radio has a front receptacle that the faceplate attaches to. This plastic receptacle has 4 screws on each side that holds it to the radio housing. In my case the plastic broke where the 4 screws are located and I guess it allowed enough slack to prevent the faceplate from making proper contact, which is why the radio wouldnt power up... Will get with AquaticAV to see if they can just send me the faceplate receptacle, will use some B-half or something on it this time around....
This bike seems to break, crack, and loosen just about everything attached to it...
