Distortion with new amplifier
Old 10-11-2015, 05:49 PM
CGLTD's Avatar
CGLTD
CGLTD is offline
Default Distortion with new amplifier
I have a Biketronics Bt 1005 and a Kenwood KMR-D562BT HU. I recently bought a Kenwood KAC-M1804 amplifier to add it. I've had this set up minus the amp for awhile now and just picked up the amplifier. I have been running the BT stuff since '06 so I am pretty familiar with it. I just never got around to getting an amp.
I got everything hooked upand get distorion when I turn the volume up. Distortion starts when volume is only up around 16. I get no distortion when I unplug the amp. There are not any gain adjustments on the amp. I am running Biketronics Titan 6.5 in the front with Hogtunes tweeter pods and Polk Audio MM651 in the rears.
http://www.crutchfield.com/S-34FA74K...MR-D562BT.html
http://www.crutchfield.com/p_113KAM1...KAC-M1804.html
Thanks in advance!
This is in a '13 Limited
Old 10-11-2015, 06:11 PM
Gannicus's Avatar
Gannicus
Gannicus is offline
Thanks in advance!
Great info CG. It's the amp brother. First and formost the amp is only producing 45 x 4 @ 4 ohms. Severely underpowered for the Titan II speakers. You need a 2 and 4 ohm compatible amp to amp your polks as well. Not sure if you listen to FM radio or not but since you already have a class D amp I'll suggest a better amp for less than the one you already have. Purchase the Power Acoustik RZ4.2000D and connect the amp to your Titan's and polks. You'll see a night and day difference with no distortion. Clear and clean at 75mph.
http://www.sonicelectronix.com/item_...RZ4-2000D.html
Old 10-11-2015, 06:49 PM
haze324's Avatar
haze324
haze324 is offline
I just put that radio in another bike and it has some good sound. I would get the RZ4 amp and wire the tweeter bar to the radio.
Old 10-11-2015, 07:34 PM
CGLTD's Avatar
CGLTD
CGLTD is offline
Thanks for the info guys. At 11 inches it seemed a bit long. Will it fit under the fairing ok? I'm not interested in losing luggage space!
Old 10-11-2015, 08:13 PM
haze324's Avatar
haze324
haze324 is offline
The side rails come off and slides right in above your radio. You do need to raise it about a half inch for it to fit with an after market HU. Run a search here there's some good pics.
If u want a smaller option check out the Cerwin B4. It's cost quite a bit more though. But the Rz4 fits and does damage for 100 bucks.
Old 10-12-2015, 06:32 AM
duglaura&flhti's Avatar
duglaura&flhti
duglaura&flhti is offline
Keep us posted, love to hear the outcome compared to your first amp. Good luck.
Old 10-12-2015, 07:37 AM
CGLTD's Avatar
CGLTD
CGLTD is offline
After looking at the Kenwood amp more i kind of had a "duh" moment. Oh well live and learn. I ordered the RZ4 and it will be here by Wednesday. I always wanted an amp, but was one of those things I never got around to. I'm sure I will be able to sell the Kenwood localy pretty quick.
Old 10-12-2015, 05:31 PM
just plain john's Avatar
just plain john
just plain john is offline
Too late now, since he's already placed his order, but I'm surprised you didn't suggest the 3000D instead. I went from the 2000 to the 3000 and the 3000 is much better.
Old 10-12-2015, 08:43 PM
CGLTD's Avatar
CGLTD
CGLTD is offline
Yup, it will be here Wednesday. I'm sure it will be pretty good considering I've never had an amp before!
I do have a question. I'll be running 10 guage and grounding at the battery. Fom what I've read a 30 amp fuse will be sufficient. Is this correct for the ground as well?
Old 10-12-2015, 09:40 PM
Gannicus's Avatar
Gannicus
Gannicus is offline
No fuse necessary on the ground bro. 30 amp fuse on the power wire is fine with 10 ga.
Quick Reply: Distortion with new amplifier
