2014 FLHTCU Help Upgrading Fairing Speakers.
Polk, along with a few others are now putting the tweeter on the grill which would provide for hard hitting bass with the woofer not having a center hole in it's structure for the tweeter mount. The jolts our entire bike takes while cruising is the likely cause of the tweeter post issue.
But this brings me to my next concern which is how will they fit if the grill is incorporated into their design. Typically it's not an issue except our cycle mount is a little unique to most other mounts, seeing as how it's behind a structure.
And if I'm placing a larger speaker into the fairing opening what's going to happen with an attached speaker grill? Is it going to work, or not... UGH!
I like the specs on those Polks. I was impressed with the 4" Polk speakers on my Tour Glide.
Edit: disregard the speaker adapters. I just seen you have a 14'
blown alcohol
09-23-2009 03:09 PM
