Amp recommendations please
Trying to figure out which amp to use. I am a newbie with audio stuff. I want an amp that will fit in the fairing. Will be running Kicker KM8's in the saddlebag lids. Currently have kicker ds525's in the fairing which I may or may not upgrade in the future. Not planning to run more than 4 speakers total. Also not trying to break the bank. Any suggestions would be greatly appreciated. Thanks.
This should do the trick: http://www.sonicelectronix.com/item_...PN4.1000D.html
http://www.sonicelectronix.com/item_...74-KSC674.html
Sound is ten times better than the one's you have in there. All you need is adapter rings.
Thanks for the input everyone.
Gannicus, will any of the standard 6.5 adapter rings work with the KSC674's?
Also will be running stock HU for now with plans to eventually change to the Aquatic AV unit. Not really concerned with FM reception.
Yep ... That will do it!! Might want to switch out the fairing speakers to these:
http://www.ebay.com/itm/SPEAKER-ADAP...-/121358701848
Note* if you get these make sure you get the set that will fit your RG. If I remember correctly the RG's are a little different. I'd just call eastern performance to make sure.
Can't wait to get my scoot back so I can get started
