Soundstream PN4.1000D ... best wire connector choice
For those that have installed the Soundstream PN4.1000D amp, what type of wire connector did you use for your power and speakers?
I am using simple crimp on ring terminals but due to the tight space issues in the front fairing (amp mounts between the HU brackets on top of the HU), the ends of the terminals restrict how far you can push the amp towards the front of the bike. Also, the RCA connectors for the preamp do the same thing. Wish the connections were on the front of the amp instead of the sides.
I can bend the ends of the ring terminal up and gain a little more space but really don't like the long term prospects of that setup.
My bike is a 2013 Ultra Classic, HU is a Sony DSX-S310BTX
Any ideas would be appreciated.
Maybe I'm not clear on your question, but power/ground wires for the amp side you don't need connectors, they go under a screw. Same thing for the speaker wire leaving the amp. Speakers generally have a slip on connector with 2 differents widths. Power and ground leads are connected to the battery with a ring lug.
just plain john: I understand that. At the amp site, I have connected my power, ground and speaker wires to crimp on ring terminals. I then secure the wire to the terminals using the screws provided. Did you just insert the bare wire into the screw hole and secure with the screw?
2010 Limited with some stuff
JoshuaCannon
Audio Systems
18
04-28-2014 02:16 PM
