Head unit
Old 09-09-2015, 08:54 PM
Mirnldi@gmail.com's Avatar
Mirnldi@gmail.com
Mirnldi@gmail.com is offline
Default Head unit
Alright my stock HK is toast. What is a solid aftermarket replacement? I need bluetooth and a cd player. $250 budget
Old 09-09-2015, 10:06 PM
RedGlide12's Avatar
RedGlide12
RedGlide12 is offline
Is your budget $250 total or just for the head unit? If you want to keep your factory hand controls the Biketronics install kit is going to run about $200. I just picked up a factory refurb Kenwood x997 and a "scratch and dent" Biketronics kit from Crutchfield and spent about $320.
Old 09-09-2015, 10:11 PM
decencyxdefied's Avatar
decencyxdefied
decencyxdefied is offline
U can get everything u need for roughly 150
Old 09-09-2015, 10:16 PM
camsmith's Avatar
camsmith
camsmith is offline
Here ya go...
Alpine CDE-HD149BT
Old 09-10-2015, 04:50 AM
JimTJr's Avatar
JimTJr
JimTJr is offline
How does this help the OP? And how can you get a new HU and still retain the hand controls for 150.00? I'm sure more than the OP would like to know that!
OP,, you can get your HU refurbished for about 250.00 at a place that specializes in the HK units. http://www.ironcrossaudio.com/
When they get done it'll be better than new from what I've heard. However this won't get you BT capability still. You are making it tough saying your budget is 250.00... of course if that's all you can afford at the moment that is all you can afford! Like Redglide said above,, the kit to make your hand controls work is gonna cost you that much almost.
Old 09-10-2015, 05:24 AM
decencyxdefied
Well smart *** stay tuned
Old 09-10-2015, 05:29 AM
decencyxdefied
https://www.hdforums.com/forum/audio...l#post14133553
See post 2, Closer to 180 not 150 sry but not hard at all within that budget..
Old 09-10-2015, 11:01 AM
Shadowbennie's Avatar
Shadowbennie
Shadowbennie is offline
Mir, I'm in the same boat. Just confirmed yesterday that my HU is also toasty, would get that same faint "pop" you referenced in another post and would lose sound or volume would drastically decrease. Yesterday, the same thing was happening with my HU running directly to my speakers instead of through my amp.
So now I'm considering my aftermarket options as well, as the stock HU is ancient tech and underwhelming compared to what's out there today, bluetooth capabilities, USB stick ports, XM or sirius, etc etc.
BUT, as to be expected, the aftermarket car stereos are not waterproof unless you look at marine radios as an option, or you have to have a separate cover, correct?
And to retain hand controls, you can look at the metra kit, which is inexpensive and works, but doesn't retain AVC (is this correct?) or the biketronics kit, which retains hand controls and also retains AVC?
Old 09-10-2015, 11:34 AM
Gannicus's Avatar
Gannicus
Gannicus is offline
Shadow - This is a really nice marine unit:
http://www.sonicelectronix.com/item_...FQaKaQodkZ8Dgw
All your assumptions are correct. You will need an install kit to control your stereo from your handle bars and the only one that retains AVC is the biketronics unit. Metra and Hawg wired do not. My favorite install kit is the Hawg wired because it's so simple to hook up and I have no need for AVC. if I want my volume up or down I just use my hand controls. Even with the marine unit you will also need a rain cover to protect your investment. Your other alternative is to purchase the Jensen or the Aquatic. At the end of the day you're gonna spend $500 bucks to switch out your radio either way you go. You can do it much cheaper but it's also a bigger PITA.
Old 09-10-2015, 01:06 PM
Mirnldi@gmail.com
Default Head unit
Thanks for the replies guys. So the $100 kit on fleabay with the mount kit and thumb control is junk?
Quick Reply: Head unit
