I installed a RF PBR 300x2 and it will not turn on when i turn my bike on. I have the power and ground wires ran to the battery and have spliced in all the wires. Any common problems for the amp not turning on?
It is the stock head unit. I talked with a friend who is an electrical engineer and he said to never ground to the battery. Is this true even though the directions say to? Also, where else is a good grounding spot?
Your bud should talk to the electrical engineers at Fosgate that published a bulletin stating otherwise for Harley's.
Have u checked that power is getting to the amp? If so, then I would try a remote wire to see if the amp turns on, if it does then it could be your speaker high level input connections. If u have power, ground and remote and it doesn't turn on, something's up with the amp.
