Shortie antenna
As an electronics guy, I can tell you that every antenna is cut to a specific length, for a specific range of frequencies. There is frequently a hidden coil of some type at the base of a vertical antenna, and it is also specific to the intended frequency range. If you cut the whip shorter, you will render the antenna useless.
To add on to the OP's question, I'm about to replace the stock antenna on my RGS with the hidden antenna that goes in the fairing. Anyone have any before and after opinions on the hidden antenna?
