Quick help before I get my radio flashed
Bout to head an hour away to get my boom box flashed.
I'm running infinity kappa 62.11's, powered by a cerwin vega b2, and I'm using the PAC converter.
Does the converter box, with its ability to adjust output levels, in anyway negate my need for a flash?
And does anyone have the link to the latest flash info, other than J&M's, as I have already read it and want to compare.
I have the PBR300 amp & Kappas. With the "Biketronics" flash I have all features working... fade, bass, treble, AVC... everything. It does need an external amp trigger wire as the flash converts the input signal to low level. I just ran a wire to the cig lighter socket.
hfdarson1
05-24-2009 06:29 PM
