aswc-1 and Metra setup
Ok. Shows its a Kenwood. But the flashes show 1st light long, next 6 flashes are short. I'm guessing that the first wire is connected and the other six arent? The only button that works is the volume up. Pink/white is connected to pink/white on harness. Iread that AAWAV had something similar happen. But i can't find anything that says what it was...btw...i installed MBBs as well...coincidence? ??
Getting my '92 FLHTC to work with the axxes brand was a major pita. I remember reading on the interwebs that the flash colors and sequence were not printed correctly in many of the brands. Did yours require cutting and grounding one of the handlebar switch wires? Mine did.
I must've hooked it up 30 different wsys/times and all of a sudden, shazam.... it worked, (decided to buy a lottery ticket that night).
Sorry...No other words of wisdom..
