Headset problem or operator error?
I just purchased a 2015 Limited , trading in my Road King. I have read the owners manual cover to cover, and seen numerous videos but can't seem to find the answers I'm looking for. When "INT" is on (active), I get no music through my headset, my passenger does. Whether I'm talking or not, I can only hear passenger communications and navigation audio. Someone said this is a safety feature by Harley so the driver doesn't get distracted. Can anyone verify this? I did find out from the dealer that with "INT" on, you get no music through the external speakers. Can I ride with a headset and listen to music??
The problem is in your settings. Are you hearing the radio through your speakers? If yes you need to change the setting for music to go to your head phones. Pages 50 and 51 in the Boom Box manual. Figure 33.
Since you are seeing "INT" your intercom is muting the radio so you can talk.
If you have a Boom Box Operations Manual (not the bike manual) the set ups begin on page 117. It sounds like you could have the mic sensitivity set way too high which is causing you to stay in the "INT" mode and not switching back to the radio.
Remember, when you set the volume for the intercom you need to be talking or else it falls back to radio volume.
Keep working with the settings. You absolutely can listen to music through those head phones. If fact, that's the best way to hear your music if your system is like mine. If I use the speakers the volume has to go to distortion levels so I can hear it at speeds about 30 mph.
I will say this also. My helmet communicators seem to lose connection at times. Sometimes you have to push the cable into the head set on the helmet until you get the missing sound.
In my case it is the passenger voice on the intercom that goes out until I get that cable pushed in just right.
I can't so far do both.
bagger51
08-09-2017 08:15 PM
