Arc audio mpak 8
Arc audio mpak 8
I have a 15 Streetglide special and want to upgrade the stereo. I'm only going to do the front fairing speakers and an amp. I know the conventional wisdom is build your own system with separate components, but I'm sticking with a plug and play set-up from one of J&M, Biketronics, or Arc audio. I've read all the reviews on the first 2 but can't find any info on the Arc audio system. Anyone have any info??
Thanks
Thanks
Of the three manufacturers mentioned, which one kicks the most ***? Biketronics. 180 watts per channel? Yes please. Which one has a lifetime guarantee? Biketronics. Stellar customer service? Biketronics. http://www.biketronics.com/bt7p1-pro...858.1422707637. http://www.biketronics.com/bt2180-14...r-2014-and-up/. That is everything you will need except a wiring kit to power up the amp.
