cerwin vega amp
should be exactly the same brother. The inputs get your speaker wires and the outputs go to your speakers. Connect the power and ground from the PBR. You might need to run a remote wire from your headlamp (orange wire) to the amp.
Chances are you cut the harness on the input of your PBR to run the high level wires. You'll need to do the same for this one, or get yourself a high to low RCA converter.
Now that i need to look for a new head unit, what suggestions do u recommend? I am only keeping this bike for a couple more years. Already have the amp, ipod interface, speakers. Just need a replacement hu. I would like to keep handlebar controls also. Ironcross will fix old for $250.00 but not sure.
Lots of good head unit choices out there. The problem is in retaining the hand controls, as well as mounting the unit itself. Almost all head units today are available with bluetooth and USB ports. Streaming music from your phone couldn't be easier. I myself run a Sony MEX unit and a biketronics Retro Radio install kit. http://www.biketronics.com/bt1005x-1...858.1422707637
