Amp for 4 polk MM651?
Need some advice on a amp, the 2.7 ohms is kinda causing me to be lost with picking an amp. I'd run 2, 2 channel amps (bridged) to get the most out of these speakers if needed and keep the ohms at the correct impedance.
The HU is a Jensen Single DIN 7" Flip Up Screen - preouts are listed at 6V if that helps.
Speakers will be in the lower fairings and the batwing. I'm open to placing the amp in a saddle bag.
Thanks for any help.
