Help with RCA issue on sony dsx310
Equipment - sony dsx 310, biketronics 7.1'a & BT480 amp
Right speaker wasn't working when I left for work yesterday morning. Before I stopped to check anything it started playing again. Thought a connection may have came loose.
Worked fine on ride home, but when I got in garage to park bike right speaker stopped again.
Pulled fairing to inspect this morning. All connections were fine. Connected right speaker amp to left rca and bingo, music again. Not much to check on the rca run to the amp, looks good.
Connected to Rear out rca and music again, but still nothing from right, front out rca.
What could have happened?
The amp I'm using is the BT480, not 4180.
Speaker connections are fine.
I guess at this point is there an issue running one speaker off "front" rca out, and one off a "rear" out? Same sound sent for both?
This seems to be an issue with the rca coming off the head unit, and can not just replace the rca. Disappointing as the HU has only been in the bike for a couple months.
