[QUOTE=just plain john;14218783]There's no need to bridge your amp[/QUOTE
That stealth 1000d doesn't have enough power to push my biketronic 7.1's. It only pushes 90w RMS per channel. I was thinking I could just bridge to get more power to both speakers until I have the funds for the $600 biketronic amp. I bridged it and the speaker that is hooked up to the bridged rear channels doesn't play. Didn't know if I needed to flash the radio to make it work.
Did you ever get that amp to fit? If not what amp did you go with?
Mike there's a post by member Scott (forgot his full screename its Scott-something) where he mounted the PN4.1000D using a mounting bracket by J&M and it fit perfect.
You don't happen to have a link to that post and pics of your install do you?
