Rear pod speakers??
Rear pod speakers??
Been upgrading my system and so far have stock HU, I have a Sony mex-m70bt but waiting for mounting parts, with a Biketronics bt4180 amp, biketronics 7.1 speakers in the fairing, kicker 40cs654 speakers in the lowers wired in parallel with the 7.1's and Kappa 62.11i in the rear pods. The Kappas are louder than the front speakers and I don't really like the way they stick out so far, I had to use the spacers. Is there any better option for the rears that would sound good but fit better? Would I have to go with a smaller speaker say a 5.25 or is there a 6.5" that would fit better? I know the Kappa's are 2 ohm and should be more efficient but If I put 4 ohm speakers back there would it sound as good? I see a lot of people are using the Kicker cs67 and wonder if they would fit better??
This is what I would do before buying more speakers. I'd move the Kappa into the lowers and the Kickers to the rear pods. I'd wire the Kappas and the Kickers in parallel on the rear channel which would put your impedance at 3ohms and run the 7.1s on the front channel by themselves.
2010 Limited with some stuff
Run the Infinity's in the lowers off the back channel of the BT4180 all alone. Run the Kickers in the rear pods and run those parallel with the 7.1's in the fairing off the front channel.
Amazon.com: Metra 82-4400 Universal 1/2-Inch Plastic Spacer Rings for 6-1/2-Inch Speakers: Car Electronics
they match the price for that. the only thing bad about them u have to drill new holes for speakers. or if u can , install them together at once using original hole that fit the speakers
Yes that's correct. You won't be able to wire in parallel. Bates is thinking series.
