Kappas Holy Crap
They are on a rotating disc so you can point the tweeters towards you when riding. I think you can just push the tweeters back into the hole, I would take a few pictures in case it doesn't work and you need to send them back with an explanation. Should work as long as the wires are not broken.
Stock grills only work if you mount the Kappas inside the pod, which I do not recommend. I had mine inside, then I put them outside like stock and they sound better. I used the V-twin grills. Call or email them and tell Brian you need the deeper grills for the Kappas.
Cycle Sounds has wire adapters if you don't want to splice, Otherwise if you are running an amp, just run new wires.
awesome info thanks
Hi, I have a 13 Street Glide, I just finished installing the PBR300x2 & the Kappas. I ran the B+ to the battery, the Ground to a bolt on the forks, and the Rem to the Cig. outlet. Did I do something wrong? When I turn the bike off the radio will keep playing until I hit the power button, though the power button won't turn it back on unless the ignition is back on.
