Biketronics Retro Radio install kit vs. Sony MEX-GS810BH
Old 04-27-2015 | 09:06 PM
just plain john's Avatar
just plain john
Default Biketronics Retro Radio install kit vs. Sony MEX-GS810BH
Has anyone installed a Sony MEX-GS810BH? It uses a two part case and the Biketronics install kit won't fit as is.
Old 04-27-2015 | 09:12 PM
haze324's Avatar
haze324
on my last Sony. I took off the outer "sleeve" so it could fit with my metra kit. I think I had to bend back a few tabs for it to slide out. If that's what we're talking about.
Old 04-27-2015 | 09:19 PM
just plain john
Maybe we are, but I've never seen a Metra kit. I'll look into it closer. Removing the sleeve I mean, not the Metra kit.
Old 04-27-2015 | 09:40 PM
Blowby's Avatar
Blowby
You have to remove the sleeve. Installed it a few weeks ago.
Old 04-28-2015 | 09:22 AM
ohiomike's Avatar
ohiomike
yes , pitch that sleeve. pull back tabs, like stated and easy-peasy fits like a glove. just installed mine yesterday. Now if only the soundstream 4.520 was the original size as stated, before they changed connection block... Damn thing is super tight fitting, wires are bent at almost a ninety. don't like it....may go back to PBR300x2, but that thing got hot...oh well, never easy lol
Old 04-28-2015 | 10:09 AM
PROVIDER7's Avatar
PROVIDER7
remove and discard the radio cage. This short clip will run you through the radio install:
http://www.biketronics.com/videos/af...-installation/
Old 04-28-2015 | 12:32 PM
just plain john
As y'all have pointed out after removing the sleeve it fit without trouble. Next hurdle...unpinning the DSX harness from the BT module and replacing it with the MEX harness. UltraNutZ did the original install on it, but I can't recall if the pins came with the connector or what. Hopefully he will reply to my text soon.
Old 04-28-2015 | 07:28 PM
just plain john
i have a Power Akoustic amp that's the same dimensions as Soundstream. I put a piece of 1x4 between the radio and amp, and it raised the amp enough to gain some clearance for the connection blocks.
Old 04-29-2015 | 08:42 AM
Gannicus's Avatar
Gannicus
Cerwin Vega B4 8.70 in. Long. Fits perfectly.
Old 04-29-2015 | 09:35 AM
AAWAV's Avatar
AAWAV
John - it will be fine, the "bending" of the cables (probably referring to the RCA's). you can also look at some 90 degree angle RCA cables on the web.
tlar1540
09-14-2017 10:43 AM
jamala00
Audio Systems
02-06-2016 07:36 PM
Gannicus
Audio Systems
06-14-2014 05:55 PM
pauly3
02-17-2012 01:17 AM
Modee1245
09-09-2009 10:53 PM
Quick Reply: Biketronics Retro Radio install kit vs. Sony MEX-GS810BH
