Suggestions
Suggestions
Recently installed a new system in my bike and so far I am not very happy with it. System consists of the following: RF PBR300X4, Rockford amp install kit and mounting plate, Infinity Kappa Perfect 6.1 in the lowers and tweeters in the gauge pods, BT 7.1 in the fairing, . and the HDPLUS2 I-Pod controller. The crossovers running the Kappa perfect 6.1 system are positioned under the ride side cover and all wiring it 14 gauge. I have se the amp gains from 5 to full on and am very frustrated. At lvl 5 the amp sounds great in the garage but down the highway you turn up the volume and it clips. When I turn the amp gain up there is a spot just before max that it is normal sounding then it just kicks. With AMP maxed it sounds great still clips around same volume level if you can stand to listen to it that loud. Heck at volume lvl 3 you can hear it a 80 down the highway but then there is no quiet volume lvl 2 is even loud. is there any flashes or settings that I am missing? I have tried playing with AVL and every other setting I could find. I am hoping there is some pros out there hat might have advice as I have a lot of time an energy in this system and would like to get it ironed out.
Thanks
Thanks
Thanks
Thanks
I have my 300x4 set around 7-8 on the dial if I remember correctly. Bass and Treble are set at "0" on the HK head unit. AVC is set at 1. I can run this system to the "E" on volume before the head unit starts sending a dirty signal and the audio distorts never any amp clipping.
I have t165 in the fairing and t1692 in the bags.
I'm not advanced enough to comment on the power handing but it shouldn't sound horrible.
Is the polarity correct on everything?
2010 Limited with some stuff
Yes I have verified polarity and it doesn't sound horrible but it doesn't sound great either. I am running AP and have tried all settings up until this point.
I am interested, can anyone tell me more about this T400x4AD amp? I see it is 499 and I can special order it from a dealer here close by that deals in Rockford AMPS. I have the inputs fed off the front speaker wires not RCAs and also I know the T400 will require a remote wire as well which the PBR didn't. It appears that the T400 is a 4 ohm amp which is good since I have 4 ohm speakers along with the fact it supports 2 channel input which is my current setup. What I want to know is how well does this AMP perform or will I buy it and regret the decision.
There's a 2 channel version as well the T400X2AD, but for the extra 50 bucks get the 4 channel in the event you ever want to expand.
I'm using one right now, and I've had NUMEROUS amps on my bike (name one) and this amp sounds AS good as the best one. It is NIGHT and day difference over the PBR. Not even in the same league. It's expensive but you get what you pay for with this amp.
