Help with amp install ?
What do you do with the gps antenna that's where the amp is going to b mounted. I assume you move it and if you do where do you move it to? Also is everyone using the OEM speaker wires or are you upgrading to better wire from the amp to speakers. I'm running 125 watts and was not sure if OEM is adequate?
vince321
Audio Systems
37
08-27-2016 12:08 PM
