Installing Polk mm651
Hey guys. So I'm installing the Polk mm651 into my 14 street glide. So far I have counter sunk the holes in the speakers and used different screws. The speakers are mounted outside the pods. Now for the wiring.....
The speakers came with crossovers. They look like just basic crossovers with no switches on them for +3 treble like others have stated. In order to mount the crossovers is it necessary to cut the ends off the factory wire that is inside the pod connected to the speaker? It seems like I need to pull that wire out and cut the grommet open to run the 4 crossover wires through it. What is your guys experience with this?
Awesome thanks for the reply. I was able to muscle the plug off. But there is no way the 4 crossover leads are going back through there to go into the speaker inside the pod. You must have to ream it out or cut it open? They will be paired to a pbr 300x2. I had planned on just cutting the factory ends off but wanted to see if that's what others were doing.
i attempted to mount the crossovers inside the pods and it killed the sound, the pods have little air space to begin with so mounting the x-over inside the pod takes up too much needed air space, I mounted mine next to the pods and zip tied them to the bracket, also use lots of polyfill inside the pod for way better sound. im running mine off a soundstream pn4.520d
