Amp for Roadglide
Amp for Roadglide
My wife has a 2003 Roadglide, and bought a tourpak from an ultra. I have put the quick release hardware on it but now I need help with an amp to power the rear speakers that are MTX 4ohm. What would you suggest. Not looking for high end. She listens to FM and an mp3 player. Will anything fit in the fairing? Stock stereo. Willing to change out stock front speakers if need be.
You could run a PRB 300X2, which would allow you to keep FM and it will tuck away nicely in the fairing. I would replace the fairing speakers with a 4ohm variety (Kicker KSC 67) and run your amp in parallel. The Kickers will run you about 100 bucks and the PBR can be purchased around $150. It'll be a nice upgrade for the money...just my .02 cents.
except the amp gains and hence the volume will change depending on whether or not you have the rear speakers installed or not.
Ok,speakers & amp came this week. I was reading the FAQ and it mentions the stock HU is 2ohm. Will this be a problem with wiring in the PBR300-2 amp. Also since her bike did not have the tour pack stock I need to run wire for the rear speakers, will this have to be done in series? I will search for a thread on wiring it but could use the help.
http://www.vtwinaudio.com/store/prod...ker-outputs-2/
