2014 SGS Magic Box Testing
Ok, let me be the clueless one here.....when you guys mention "pods" are you referring to the white plastic covers that are over the speakers on the 2014 and up bikes? And what exactly is this mentioned "Magic Box" and what's it's purpose? I just installed a RF 300x2 amp with Infinity Kappas 62.11i on the way. Want to get the best sound possible on my 2012 SG.
Outside the pods means just like stock, remove 4 screws that hold speaker to the pod and remove/install speaker. There as an alignment nub that will need to be ground off. Inside the pods means remove the pods, split the pod in 2 halves, there are I think 5 screws to split the pod. Then you mount the speaker on the inside and then put the two halves back together, I.E. you have to split the pod to remove or install the speaker. get it?
