SoundzCustomz Level 4 w/ lids - video after install
Old 02-18-2015, 08:53 PM
Spazz's Avatar
Spazz
Spazz is offline
Default SoundzCustomz Level 4 w/ lids - video after install
I cannot believe the clarity and performance of this system! I had it down at HD today next to a Boom II and I blew it away and I'm not even past the break-in yet....
Big Thanks to Peter Jensen of SoundzCustomz for putting together an awesome system!
Here's my video.... incredible!
EDIT:
I wanted to put this here in case people were curious ( other flash threads are out there as well ).... RECOMMENDED FLASH for me was 2 amp ON and 8 speaker ON... This resulted in a binfile of 135_OFF ( FADER inactive ) I use the front speaker outputs of the factory HU to split to front and rear inputs of the amp... no need for a fader.
Second video AFTER break-in
Old 02-18-2015, 09:05 PM
haze324's Avatar
haze324
haze324 is offline
I thought you were going to go around the block!
Man you can really tell the quality of the HAT 6X9’s when you come across the lids recording.
Sweet set up man! Clean clear sound travels far!
Old 02-18-2015, 09:22 PM
Spazz's Avatar
Spazz
Spazz is offline
Thanks! I am super pleased with this system.... I am glad I spent lots of time researching audio before I dropped coin on something that I most likely would have thrown away....
Old 02-18-2015, 10:03 PM
acchd's Avatar
acchd
acchd is offline
Very nice setup always liked Arc amps for there clean sound & reliablility. The xdi600.4 has nice footprint and great specs.
Old 02-18-2015, 10:12 PM
dgreen1069's Avatar
dgreen1069
dgreen1069 is offline
Sounds awesome! Congrats and enjoy!
Old 02-18-2015, 10:34 PM
lyork's Avatar
lyork
lyork is offline
Did the Imagine 5x7's fit right in to your lids? I read where someone else said they could only get 3 out of the 4 screws in.
Old 02-18-2015, 11:09 PM
bigreds1963ss's Avatar
bigreds1963ss
bigreds1963ss is offline
Hats off to your bad *** system.... Did you have the head unit flashed or did you use a magic box? how did you run the 4 channel amp setup with 2 sets of rca outputs? I have a 2014 SGS as well and ive got the polk mm651's in the fairing in the pods with lots of polyfill and the speakers are seeing roughly 140 watts each. I am awaiting my bag lids so I can add them to my other 2 channels on the amp, sweet setup!!!!!
Old 02-19-2015, 06:11 AM
Spazz's Avatar
Spazz
Spazz is offline
They are not a direct fit as the holes do not line up... I actually clearanced all 4 mounting holes in each speaker to get a better fit with no flex on the base plate... oh.. don't forget you need gaskets to help keep the water out of the bags.
The recommended flash for me and my sled was 2 amp on 8 speaker on ... apparently the flash that can or can't be done depends on the VIN ( what I was told )
I had the configuration done for 2 channel input and split with RCA's to the rear....no fade control... but I didn't need it anyway....
Old 02-19-2015, 06:33 AM
ducatidesmo's Avatar
ducatidesmo
ducatidesmo is offline
From what I understand, the fade control is done at the amps when they are set to yes. if it can't detect the amps, the radio turns the fader control off.
Old 02-19-2015, 07:58 AM
duglaura&flhti's Avatar
duglaura&flhti
duglaura&flhti is offline
Congrats on the NEW upgraded tunes. Looks cool & sounds primo ...D
Quick Reply: SoundzCustomz Level 4 w/ lids - video after install
