High Level Input wiring?
02-04-2015, 09:47 AM
SS PN4.520D AMP.
Looking at the pic below, the + & - don't match between the printing on the back of the amp and plug wires that go in them. Which do I go by?
02-04-2015, 09:53 AM
Bertk, IIRC someone had this same question a little while back and the answer was to always go with what's printed on the amp.
02-04-2015, 09:58 AM
Quote:
Originally Posted by
Little Mike
Thanks for the quick response. That makes sense, I don't want to wire it the wrong way and have to redo it.
02-04-2015, 10:07 AM
Just got this from UN to confirm it.
go with what's on the amp.
Front from left to right should be +-g-+. ignore the g and tape that wire off
Rear from left to right should be +-g-+ as well. ignore the g and tape that wire off
02-04-2015, 10:29 AM
When I still had the stock head unit, I went with the amp, worked fine.
02-04-2015, 09:58 PM
Yes that worked. Got the amp installed today.
02-05-2015, 05:48 AM
I'm just curious, why not use the RCA's?
02-05-2015, 06:21 AM
Guessing he's sticking with the stock head unit. That's what I did initially
02-05-2015, 07:34 AM
02-05-2015, 05:29 PM
I had the same PN4.520D behind the stock head unit. NutZ convinced me to try an aftermarket radio (Sony) and it really made a huge difference sound wise. The amp killed FM, but the bluetooth built into the radio makes that a non issue. The USB port is handy for charging your phone too. Do you listen to FM?
